Switched out sway bars - FirebirdV6.com/CamaroV6.com Message Board
  • Switched out sway bars
    I switched out my ST 35mm sway 34LBS for a 1LE 32mm hollow 11LB sway. The 35mm is def. made for a firm, tight steering but I feel the 32mm I have more feel for the road with it. More sensitive feeling with the 32mm. But if your auto crossing or want a tight steering a 35mm and 21mm rear is perfect. I mainly did this for the 23LB weight savings and more room for my turbo setup. Like most have said a 32mm front and 19 rear would be the best setup for DD.
