I'm looking for the best inexpensive thing(s) to reduce body roll. Been auto xing lately, and I've been loosing time to make up for intense body roll. I've been looking at sway bars. Good move, or is there something a bit better for the money out there?
Best cheap thing to minimize body roll
Re: Best cheap thing to minimize body roll
Cheap, quick, easy, and effective usually never come together in one sentence when it comes to modding cars, however, I think I can say that you can get some solid gains with minimal cost out of pocket on this one with a set of 32/19 factory sway bars off an SS or WS6. Check out the V8 boards. It will reduce body roll significantly without any real adverse effects because it's a safe combo and OE equipment on other cars.
You may even be able to find guys selling them for cheap with poly bushings and even endlinks. I think I spent under 120 bucks for both front and rear with ES bushings and endlinks, and it was a great improvement in handling. Or you could just go for the front bar, which will reduce your body roll a lot but give you some understeer.
Sway bars, Shock tower brace, subframe connectors and springs/shocks and your pretty much all set.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
i second that^^ i did most of my suspension as a package so it's hard to say individually which part had the greatest impact but i can say i did my subframe connectors separately and they made one hell of a difference.pacesetters|full 3" borla exhaust|3" stainless e-cutout|slp cai & ram intake|c/f whisper lid|tbs|eibach|kyb|stb|sfc's|adj.lca's & phb|slp fan|b&m t5|180*|z06 17x9.5|8000k hids|hptuners|d/s rotors
gone in body, but not in spirit
^ yes my car felt like superman around corners after we got through putting on the sub frame connectors, I had the STB too and just about everything else. But when I took my STB off here lately I can noticed the difference, also changing my front sway out from a 35 to a 32 sway made a difference.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
My favorite suspension mods were sway bars, springs, and SFC/STB, though I noticed a bigger everyday (non performance) gain with the shock tower brace, namely entering slanted driveways at an angle, car felt much more solid. Sway bars reduced body roll the most, and the springs just made the car feel like new.
Originally posted by Shad0wguy View PostPoly bushings would be a good starting point.
So at this point, a 1LE front sway bar would be your best bet. Get some poly bushings and endlinks to go with it, along with some grease, and you'll notice a difference in body roll.
Originally posted by 3800SoloWing View PostDoes the size matter (19mm - 32mm), and also what are the recommended brushings?
Here's one for sale at a good price.
http://cgi.ebay.com/ebaymotors/93-02...205|240%3A1318Last edited by pace2006; 06-09-2009, 12:02 PM.'99 Camaro
'04 Saab 9-3 Aero
'90 Audi Coupe Quattro
if you only want to do one mod it would have to be subframe connectors hands down
x2 for sfc's best bang for your buckpacesetters|full 3" borla exhaust|3" stainless e-cutout|slp cai & ram intake|c/f whisper lid|tbs|eibach|kyb|stb|sfc's|adj.lca's & phb|slp fan|b&m t5|180*|z06 17x9.5|8000k hids|hptuners|d/s rotors
