Although I plan on getting both I'd like to know which one I should get first frame ties or a torque arm relocation kit.
Which first
Re: Which first
I have Hotchkiss 1.5in drop springs sensatrak shocks up front and air shocks in back. That's about it. It handles well due to the 17x9's in front and 17x11's in back. I'm looking for a little more off the line.
Re: Which first
If your happy with the way it handles then go with the torque arm first. Get an adjustable one so you can dial in the pinion angle. If you dont have aftermarket rear lower control arms I would get some. It makes a huge difference.
Re: Which first
Originally posted by techsan23 View PostIf your happy with the way it handles then go with the torque arm first. Get an adjustable one so you can dial in the pinion angle. If you dont have aftermarket rear lower control arms I would get some. It makes a huge difference.'99 Camaro
'04 Saab 9-3 Aero
'90 Audi Coupe Quattro
