options for track bar?? - FirebirdV6.com/CamaroV6.com Message Board
  • options for track bar??
    What are my options for replacing my track bar on my 98 V6 Camaro? Its the bottom piece in the pic. Mine is bent, and I want to know if there's something beefier than stock, or just whatever is available?? Thanks!
    Re: options for track bar??
    http://www.umiperformance.com/catalo...roducts_id=113
    there ya go!
    Team NoVa
      Thanks!!!!!!!!!!!!
        Or you can go BMR too , I have had a Chromoly adjustable one for 9 years and is holding up great ,along with their LCA's and sub frame connectors. UMI is a great CO. also so it would be up to you. I have products from both CO. and their great so far. 97RS4LIfE has a site that you could check out , always has great prices. I think he has UMI products, Grand Valley Specialties, I think is the name of his site.
          hotpart.com i love their products =)
          2001 Camaro 3.8 A4
          1991 3000GT VR4
          2001 Mitsubishi Eclipse GS
            I'm going to order the one from UMI this week. Best price I have found! I can't wait!!
              I'll say this for the 1000th time - a tubular PHR is BS!
              It is a total lack of understanding a suspension.
              The shaft MUST twist!
              The factory PHR is fine, just replace the rubber bushings with ES.
              If you need to be high tech, use adjustable rod ends.
              Raven
                FirebirdGT... I've read your posts about the panhard bar and was wondering if you could point me in the direction to find a "non" tubular adjustable panhard bar, I haven't been able to find any by doing some casual searching...
                Custom interior...
                TEAM NoVa
                  You miss the point.
                  http://www.globalwest.net/1982-02_Ca...ntrol_arms.htm
                  Raven
                    Originally posted by FirebirdGT View Post
                    ...and those are lca's
                    Team NoVa
                      Same binding principle applies.
                      Raven
                        why would the lca's need to twist??
                        Team NoVa
                          they need to articulate when you go around corners...if they don't then you will get bind, and it will put more stress on the mounting point of the lca...
                            but my question is... you need an adj. phr to re-center the rear after lowering right? ...along with lca relocating brackets... so if tubular phr's aren't any good, what other options are there for an adj phr... I mean, I'm not going to be autocrossing my car or full-out drag-racing, so I'll probly just go with something cheap from a reputable co.... I'm just curious, I guess...
                            Custom interior...
                            TEAM NoVa
                              I have ran my ADJ.chromoly BMR panhard rod with poy endlinks 9 years and haven't had any problems. My whole suspension is almost all poly except for the front lower A-arms that came with one rod end and I don't have any problems with that one either. Mine is a street car , never taken it to the track, might one day in the future.
