okay say your hood is popped and your in front of your car (3.8) your powersteering overflow tank is to your right it has 2 hoses coming off going down i ordered a return hose the otherday and it was the smaller of the 2 (the one closest to the firewall) what is the one that is closest to you (thicker of the 2) called? its not the pressure hose i tried that and it is a small hose that hooks the pump to the rack.
help me identify this powersteering part..
Re: help me identify this powersteering part..
by hooks the pump to the rack....
the hose you need goes from the power steering pulley to the steering rack on the very bottom of the engine?
26064197 should be the gm part number
but as for the actual name of the part, it's listed as simply a hoseLast edited by Meatyshells; 07-27-2009, 06:45 PM.
