SOMETIMES when I pull the lever on my e brake it doesn't always light up on my dash any thoughts ?
e brake
Re: e brake
Connector for E-brake or like Meaty said contact point is bad.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: e brake
To get the console off on an a4, you open up the center console, and there's two little bolts in there... take those out, and then the middle piece should lift up. to get the entire base off (to get to the airbag unit and some other wires and crap) there are more bolts in the bottom of the center console and a couple up under the dash below the radio and stuff... they kind of bolt onto two metal tabs that stick out, one on each side.
I'd go take some pictures, but my car is at my house, and sadly I'm at college without it... :(
Re: e brake
get a small screwdriver and pry the clip out that holds on the shifter, and take those couple of screws out, its really easy.Team NoVa
Re: e brake
Originally posted by inheritthefire View PostTo get the console off on an a4, you open up the center console, and there's two little bolts in there... take those out, and then the middle piece should lift up. to get the entire base off (to get to the airbag unit and some other wires and crap) there are more bolts in the bottom of the center console and a couple up under the dash below the radio and stuff... they kind of bolt onto two metal tabs that stick out, one on each side.
