Hi all,
I'm Mike from Slidell LA. Found me a 1998 Camaro (base) with a good running 3800 and decided to spend a lot of money to make it go fast.
Current parts include:
INTENSE Stage 4 Heads
INTENSE Stage 4 Turbo Cam .050" 226/218, 116 degrees
ZZP roller rocker arms 1.65:1
JP Performance Double Chain Timing Set
CompCams OE R Series Hydraulic roller lifters
INTENSE Extreme duty oil restricted push rods
ARP Head Studs, Con Rod bolts, Main stud kit, Main cross bolts
CompCams double spring retainer kit (130#)
Manley severe duty Gen II valves
Diamond Uncoated Forged Piston/Pin/Ring kit 8.5:1
L32 ConnRods
Borg Warner SX AR.91 66mm Turbo
38mm wastegate
OBX-R high performance inline BOV
Mishimoto Z-Line intercooler
Homyl 3" downpipe
Flowmaster American Thunder CatBack
3" high flow cat and resonator
Fuellab regulator
Siemens Deka 60# injectors
ZZP 130lph fuel pump
Centerforce dual friction clutch
Pro 5.0 short throw shifter
Meziere electric water pump
and a bunch of glowshift gauges, and fun stuff.
I plan to spend the next year making all this work together and tune it with a goal of 500+ HP.
Hoping to learn from the vets here and make new friends along the way.
L32 ConnRods
38mm wastegate
Homyl 3" downpipe
Fuellab regulator
