I drained my tranny fluid and a lot got into the gutter in front of my house. It has been sitting a while and i cant clean it out with anything. Any suggestions?
tranny mess
your gutter? did you drain your tranny fluid while your car was on the roof of your house?
BUT, if by gutter you mean area outside your house in the street, you can use catnip, or OilDry from pepboys.
and tell me, why did you not drain the fluid into a pan? what'd you just unscrew the plug and walk away?
Originally posted by 95fbirdkid:
And i'm glad to see this is about your transmission, when i read the topic i thought for a minute you had picked up a hooker and it turned ugly.
Try spreading cat litter on it, letting it soak for 10 mins, grinding it with your feet a little, then sweeping it up. If theres still any left they do make driveway solvent you can get from most autoparts stores that will help clean it. My old 79 dumped about 4qts of tranny fluid on my in-laws brand-new driveway one day and I was able to clean it up with that solvent, a hose and a junk broom (to scrub)
Good luck<b>Trucks</b> <br />\'05 Dodge 3500 Dually <i>Cummins Turbo Diesel</i><br />\'98 Dodge 2500 4x4 <i>360 V8 (Wife\'s)</i><br /><b>Toys</b><br />\'81 Chevy K10 <i>Stroker/Swampers/Custom Suspension/1-Tons/Beadlocks</i><br />\'99 Camaro Z28 <i>6 Spd, T-tops, Borla</i><br /><br /><b>Real trucks don\'t have spark plugs</b>
Try getting the hose and spraying it down the closest sewer drain.<b><a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six©</b></a><br /><a href=\"http://www.sounddomain.com/id/95batmobile\" target=\"_blank\">My \'95 Bird</a><br />I am not afraid of storms, for I am learning how to sail my ship.
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
