I just hooked up my D-link DI-624 wireless router and my roommate and I both got the DWL-g520 PCI cards to go with it. I've updated all the drivers on both the router and the cards, but my problem is whenever I have the PCI card enabled it causes my computer to freeze. My roommate doesn't have this problem, but on his computer it seems to be laggy as if you were playing a game. Anyone know how to fix either problem?
Help with my wireless network
Chipset drivers would most likely be the culprit you may want to update those that way you will have the most recent driver build for the PCI bridge if still no luck try a older version of the network card's driver make sure its WHQL certified.<a href=\"http://www.cardomain.com/id/exzodious\" target=\"_blank\">2000 Pontiac Firebird</a>
Originally posted by eXzodious:
Chipset drivers would most likely be the culprit you may want to update those that way you will have the most recent driver build for the PCI bridge if still no luck try a older version of the network card's driver make sure its WHQL certified.<a href=\"http://www.xbox3604free.com/default.aspx?r=381546\" target=\"_blank\">http://www.xbox3604free.com/default.aspx?r=381546</a>
