found me some new motors
:naughty:
what do u guys think i should go with?
:naughty:
- 383 Lt1
'95 4 bolt Corvette Block Billet main caps with ARP studs
Callies RaceMaster crank
Oliver 6" rods JE dished coated pistons
LT4 Extreme timing gear
ATI balancer
lightweight billet flywheel
Mini gear reduction Powermaster starter
custom solid roller Comp cam (248/257 .605/.611)
Canton Road Race oil pan
Custom LT1 ported heads by GTP, cermaic coated stainless valves, chambers, and exhaust ports
T&D shaft mounted rockers
MORE Performance ported LT1 intake, powder coated black
AS&M 58mm billet TB
ATI D1SC head unit with HD brackets 12 rib pulley for 15psi HD Tensioner
Comes complete with all accessories, brackets, sensors, wiring harness for Camaro and engine computer.
Does not include fuel injectors
Motor has break in miles on dyno, no full pulls have been made
5 days left at $2650 now reseve not met.. - Lt1 Stroker Engine
block work: hot tank, magnaflux, line honed if needed, bored .030 over then finish honed with deck plates. New Eagle 3:750 stroke cast steel crank, Eagle 5.7 new connecting rods, speed pro hypereutectic pistons and rings(your choice of flat top or dished pistons. Flat top yields 11.8:1 compression and the dished yield 10.6:1. Clevite rod, main and cam bearings. Lt1 Aluminum heads with 3 angle valve job .600 max lift valve springs. Lightly ported on exhaust, pocket ported under valve head, and gasket matched on the intake side. Custom ground cam, 230/236 duration @.050 with .540 lift on intake and .550 on exhaust. If different cam desired please specify.Competition Cams 1.6 Ratio Roller Tip Rockers. New timing Chain, this motor is the pin drive distributor, if you need the spline drive please specify. Lt1 fuel injected intake, ported to match cylinder heads.Complete Assembly balanced and blueprinted
they will build it any other way u want to $3075 to buy - or i found a stock ls1 64k miles come with a 6 speed tranny and the cross member and everything else i need for the swap it was $4000 something
