As the title says, is there a MAP/MAF sensor on the carburated 2.8L V6 found in the 1984 Firebird? I found the connector for the MAP/MAF sensor, but can't seem to find the sensor itself. None of the manuals seem to help either. I know I should get the shop manual as that would solve the issues caused by multi year manuals......
Help?
[ January 18, 2003: Message edited by: Jurrel ]</p>
Should have a MAP sensor on it. The clip was on the firewall, right? Had a carburated 1983 Camaro and distinctly remember having replaced it at some point.
<a href=\"http://home.earthlink.net/~spcboshears/\" target=\"_blank\">That other car is going to give Trans Am a terrible reputation</a>
It looks like a MAP sensor but it's a BARO sensor. It's small and rectangle, with a vacuum port and an electrical connector. Some are mounted on the cowl right at the bottom of the windshield......
