Window Motor - FirebirdV6.com/CamaroV6.com Message Board
Window Motor
  • Window Motor
    Hey kids. . .my passenger side power window is on it's way out. How hard is it to replace the motor? Is there a possible rebuild?
    --Troubled in Guymon
    1992 Arctic White Firebird<br />3.1L V6, TB Coolant Bypass, CAI, Turbo Muffler, other little things.<br /><br /> <a href=\"http://www.geocities.com/colinobu/MyHomepage.html\" target=\"_blank\">http://www.geocities.com/colinobu/MyHomepage.html</a> <br /><br />\". . .Finger in the air and the flag still wavin\'. . .\"
    Are you sure the motor itself is going out? If you haven't already, pop off the door liner and make sure everything is where it should be, all the connections are right and nothing is loose in there. I looked at a car that the windows would only go up and down whenever it felt like it it seemed and the only problem was a loose wire to the motor. If the motor is indeed going I'd hate to see what a new one would cost. GM rips us off hardcore on some of these parts. (Firebird headlight motors)
    David
    1995 Nissan Hardbody King cab XE, 5-speed, 4 banger<p>Looking for the right Camaro...
      call around to autoparts stores. I think AZ has a replacement for like $60 or so w/lifetime warranty.
      2013 Ram 1500 Big Horn
      94 comero 3.4
        If its shot, try the junk yards first. Might be able to find a motor there even though you prolly wont be able to test it. Worth a shot. If you end up with a dud, your out 5 bux.
        91 Camaro RS 3.1 Auto<br />CAI <br />TB Bypass<br />Dynomax ST Catback Exhaust<br />15x7 AR Gamblers on GT Qualifiers<p>Dont Mess With The RS
          What's really **** -eyed is this only happens in the summer. During the cooler times of the year, the window goes up and down like normal, but when it's warmer, it's noticeably slower and sometimes will stop mid-raise and I'll let off the button for about 30-45 seconds and it'll go up a lil' more and stop and I'll end up repeating this process over and over again until the window's up. I kinda' wondered if it was a connection in there someplace or--at a long shot--the fuse, but ruled that out since the fuse runs other stuff that works just fine.
            on my 90 bird, drivers side rolls down about 5 inches and then goes tataatatataatatattaatatkjakdaktjktjaktjka like that and wont go any more is the motor shot?
            <blockquote>quote:</font><hr> (Firebird headlight motors)
            <hr></blockquote>
            Yepp my lights are always up too, dang motors...
            1997 30th Anniversary A4 w/ some mods
              No, your motor is not shot. If you hear the noise, you have to think that there is something in there that is the source of the noise. The only possible solution is the motor makes the noise. My guess at your problem is that the regulator is bad. The regulator is the brackets that look like a large pair of scissors. The regulator controls the upward and downward movement of the window. The gear on the motor meshes with a gear plate attached to the regulator. If the teeth are bent or misshapened on one end of the gear plate, it will cause problems. Also, if debris is trapped in the channels, it will hinder the window's movement. The channels are the guides that keep the window in place as it moves up and down.
              Jim
