Code 42 - FirebirdV6.com/CamaroV6.com Message Board
Code 42
  • Code 42
    ESCT or whatever the fudge it is. Who here has dealt w/it? I have the service manual, but all tricks of the trade are welcome ;)
    Once this is fixed, car should run correctly. Surges now, but the exhaust leak is fixes, and dayum, that dynomax cat back is awesome sounding [img]graemlins/omg.gif[/img] [img]graemlins/thumbsup.gif[/img] [img]graemlins/thumbsup.gif[/img]
    2013 Ram 1500 Big Horn
    94 comero 3.4
    You may already know this much but in the sheets I have it says code 42 is:
    - Electronic Spark Timing (EST) circuit - open or shorted to ground during engine run.
    - Direct ignition system (DIS) fault - bypass circuit open or shorted during engine run
    - <a href=\"http://www.thenebula.com/carpics/pics2/camaro2.JPG\" target=\"_blank\">White \'99 V6 Camaro</a> (M5, 3.23s)<br />- 3\" Borla Exaust, RK Sport Induction Lid, Fast Toys Ram Air, K&N Air Filter, !Silencer, !MAF Screen, B&M Short shifter, Manual Fan Switch, 160° Hypertech Powerstat, BMR Boxed LCAs(rubber/poly), BMR STB<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=386884&page=1\" target=\"_blank\">*My Cardomain Website*</a>
      I am guessing that you already checked the connector for the timing. This is the connector that you unplug to check your base timing. If the connector is bad or corroded, it will set this code. Besides a bad computer, I think the only thing that will set that code is a bad/loose connector or wire.
      Jim
        <blockquote>quote:</font><hr>Originally posted by Jerriko:
        Jim
        <hr></blockquote>
        You guessed wrong. Which connector is it? None of the material I have, or can find, says where it is.
        94 comero 3.4
          I ran across this on another forum, actually a S-10 forum so things may not be where it says, maybe it will help anyways.
          <blockquote>quote:</font><hr> That code you have is usualy registered when you unhook the wire for setting your timeing. Check to see if its connected or not its on the pass side just above the carpet only wire that sticks out of the harness that goes thru the firewall.
          If thats not the problem you will want to check your knock sensor and the controller for it (black box on firewall by wiper motor) and all related wireing. <hr></blockquote>
            <blockquote>quote:</font><hr>Originally posted by V6MaroFL:
            <hr></blockquote>
            Actually,
            READ THIS, it looks like it wasn't making a connection, among other problems.
            Thanks for the info, and feep up the good work [img]graemlins/thumbsup.gif[/img] [img]graemlins/thumbsup.gif[/img] [img]graemlins/thumbsup.gif[/img]
            94 comero 3.4
              Ok, glad that helped. If you still haven't found the connector, mine is located in the wiring harness around the blower motor. The connector will be hanging out of the wiring cover. The wire is brown with a black stripe.
              Jim
