3.4, I have a question for you... - FirebirdV6.com/CamaroV6.com Message Board
  • 3.4, I have a question for you...
    I got the motor in the car. I need to know if you had any problems with the firing order (or ignition system).
    Origonally, I had the distributor 180* out. Didn't seem to want to run for some reason [img]graemlins/slap.gif[/img]
    2013 Ram 1500 Big Horn
    94 comero 3.4
      It not that, I just can't seem to get it to fire.
      :mad:
        What exactly is/isn't it doing?, hit the chatroom ;)
        94 comero 3.4
          It's not grounding the injectors. I have spark and compression, no fuel. I have good fuel pressure and I manually tested the injectors, they work. Does the ECM grounds connect to the back of the engine? I have thinking that I didn't clean the connectors as well as I thought and the ECM may not have a good enough ground.
            you should have some grounds on the back of the heads, and a braided strap from teh firewall to the engine.
            94 comero 3.4
              Yes, they were all connected but between the rust on the studs and the paint on the motor, hopefully that was the problem.
                Does she ride?
                94 comero 3.4
                  Haven't tried it yet. I have been too busy parting out an 87 GTA.
                  :D
                    Oh, and dealing with the aftermath of a small engine fire.
                    :mad: [img]graemlins/slap.gif[/img]
                      <blockquote>quote:</font><hr>Originally posted by Jerriko:
                      <hr></blockquote>
                      sounds familiar :(
                      edit: how's the hood for it? ;)
                      [ January 05, 2004: Message edited by: 3.4 slow to go ]</p>
                      94 comero 3.4
                        Luckily, the hood was off and I managed to get the car outside. The injectors, injector wiring harness, injector rail, driver side headlight assembly, fuel pressure gauge, headlight wiring harness, power steering switch, windshield washer reservoir, detent cable and battery were not so lucky. [img]graemlins/crybaby.gif[/img]
                          [img]graemlins/omg.gif[/img]
                          edit: maybe that's why i aint running right. Mine didn't either after it's fire too :( :( [img]graemlins/crybaby.gif[/img]
                          [ January 06, 2004: Message edited by: 3.4 slow to go ]</p>
                          94 comero 3.4
