Trans - FirebirdV6.com/CamaroV6.com Message Board
Trans
  • Trans
    What kind of trans does a 1992 3.1 bird have (4spd auto)
    700r4? 4l60e?
    also, I assume the bellhousing is different than V8 cars right?
    1999 Camaro Z/28
    1973 Firebird Formula
    Re: Trans
    it's a 700r4, the 93 A4 is a 4L60, which is the same thing. the 4L60E which started in 94 is where the shifts are electronic.
    Yes, the bell housing bolt pattern is diff than the sbc.
    2013 Ram 1500 Big Horn
    94 comero 3.4
      Re: Trans
      thanks
      1999 Camaro Z/28
        Re: Trans
        Not that it matters but i belive the input shaft is also a different length.
        Daily: '02 Black Yukon Denali
        Toy: '06 Torrid Red GTO
        Gone: Powerdyned '02 Pewter Camaro
        Gone: '07 Charcoal Yamaha R6
        Gone: Ex-wife, lol
          Re: Trans
          so...if doing a V8 swap...I would need a new bellhousing, V8, motor mounts and suspension...
          just out of curiousity
          1999 Camaro Z/28
            Re: Trans
            no, you'd need a v8 tranny, and one that would match your gauge cluster.. i.e. either a speedo cable style, or vss style.
            for front suspension, going cheap-ie would be just swapping in v8 springs, v6 will lower your car a lot (been there, done that, even had a strut fail)
            94 comero 3.4
              Re: Trans
              I actually found that out after I posted...
              I was actually looking to see if they made bellhousing adapters that would bolt to the V6 trans to the V8 engine...
              do they make these?
              1999 Camaro Z/28
                Re: Trans
                I thiink they do..... but I'm not sure if the input shaft has the same splines for 6cyl &8cyl converetors.
                94 comero 3.4
                  Re: Trans
                  Yea, after looking at everything in detail, a V8 swap looks like a major pita...
                  I actually found a 307 V8 powered bird for 300 that i might buy and use the interior for the 6er
                  1999 Camaro Z/28
                    Re: Trans
                    OK, either:
                    a) IT's a bored 305 (not sure what the math makes it out to be....
                    or
                    b) Someone, for some reason, swappped in that old-mo-bubble engine inthere, w/a B-O-P tranny & swapped the tail housing or has a frame mount torque arm.
                    V8 isn't all that hard IF you have all the parts needed on hard, or at least a majority of them.
                    94 comero 3.4
