So I've managed to get the UIM/LIM off of my 98 3800. I've removed the valve covers and the 4 bolts from there. However, I can't seem to figure out where the other bolts are that I need to remove. Are they the bolts under the exhaust manifold? I removed the shroud covering the exhaust manifold on the passenger's side, but there isn't enough clearance to remove it fully.
Help needed for pulling heads
Re: Help needed for pulling heads
Yeah there's a few under each manifold, and I think 1 or 2 on the front of the passenger side head.1997 Chevrolet Camaro
L26, Pacesetter headers, SLP cai, Centerforce DF clutch, Pro 5.0 shifter, UMI short stick, 1le driveline, J&M 35mm front swaybar, UMI lca's/phb/sfc's, KYB AGX shocks, Hotchkis stb.
Originally posted by Inverted View PostSo I've managed to get the UIM/LIM off of my 98 3800. I've removed the valve covers and the 4 bolts from there. However, I can't seem to figure out where the other bolts are that I need to remove. Are they the bolts under the exhaust manifold? I removed the shroud covering the exhaust manifold on the passenger's side, but there isn't enough clearance to remove it fully.
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...3 days ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....1 week ago
