Gaskets for a cam install - FirebirdV6.com/CamaroV6.com Message Board
  • Gaskets for a cam install
    Well im going to do my cam install in two weeks, but i have one last question. I know that there is alot of gaskets that need to be replaced whille doing such an install. (ie water pump, timing chain cover, fuel pump, oil pan, valve cover). Anyway... I know that they are sold in Cam instll kits for the v8 does anybody know if the make it for the v6 as well, and if so where to get it from?
    Too many mods to list! To see what I have done, check out my car domain website --&gt;<br /> <a href=\"http://www.cardomain.com/id/2k2firebird21\" target=\"_blank\">http://www.cardomain.com/id/2k2firebird21</a>
    I never could find one.
      http://www.zzperformance.com/zzp/pro...nstall_kit.htm
      02 Firebird NX wet kit, MAFT,Coated pacesetter headers,ORP, Borla catback, !fra, whisper lid,NGK TR6\', taylor wires, hpp3, autometer gauges, 30th and 35th stripes,macewen silver gauge overlay, painted interior and calipers, ww spoiler, transgo shift kit, corvette servo, BMR stb,boxed lower control arms, custom subframe connectors
        Get the GM part number for your car (at the dealer) and order it from GMParts direct.
        They have gasket kits for this specific thing.
        ZZP sent me a whole mess of wrong crap. Be careful.
        I do happen to have an L67 supercharger gasket, if someone needs one!
        EDIT - You don't need an oil pan gasket, despite what they tell you.
        1997 Dodge Viper GTS
          Yeah i think the ZZP gasket kit is for FWD 3.8's which do indeed have different intake manifolds as well as other things. Best bet is to pickup a gasket kit part # from your local dealer and order through Gmpartsdirect. I had the part # but cant seem to find it atm. So yeah, exactly what AZ said.
            I just did a CAM install and I used the ZZPerformance install kit for the L36 motor. They were perfect. Don't remove the throttle body or the water pump and you won't need those gaskets. They don't come in the kit but you don't need them. I had to get those seperatly because I had a P&P job done on the intake so I removed the TB.
            The only problem I had was the crank shaft bolt was wrong. I got the right one from GM. I told ZZPerformance about the bolt so hopefully they have corrected the problem. Good luck.
            2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
              You also do not really need valve cover gaskets unless yours are currently leaking. They are neoprene and reuseable.
              I know this stuff is logged somewhere but here is a list I made a long time ago for parts and numbers. Double check the numbers as GM changes them sometimes.
              24503515 Rocker Bolts 12
              24504668 Timing Chain
              24502252 Timing Cover Gasket
              24504789 98 Upper Intake Gasket
              12480831 98 Lower Intake Gasket Kit
              12537616 95-97 Upper/Lower Intake Gasket Kit
              12539095 95-97 Upper/Lower Intake AND Head Gaskets
              24502433 Thermostat Gasket
              24503432 95-98 Throttle Body Gasket
              20x4 Fine Thread – Bolt to thread in cam for removal/install.
              Tools needed:
              Pulley remover tool (steering wheel remover tool will work)
              Pulley installer tool or Impact gun
              15/16 impact socket for crank pulley bolt
              1 and 1/8 impact socket for cam gear bolt
              Plastic fuel line removal tool
              Michael Huff<br />92 RS, 98 V6, 97 SS, 00 Z28 <br /> <a href=\"http://www.carolinafbodyclub.com/\" target=\"_blank\">http://www.carolinafbodyclub.com/</a>
                wow...its Ironman24 [img]smile.gif[/img]
                  when i got my short block made my machine shop gave me a gasket kit from fel pro everything worked so maybe check fel-pro
                  1999 Firebird 3.8 Chamelon<br /><br />MagnaFlow Catback<br /><br />Devon
                    thnaks you guys for all your help. I actually went to a local performance shop and had them look at the tech sheest for a recent cam install job they had done on another v6. I told them to order the parts i need . so far its worked out good.
                      Still trying to find oil leak
                      3 days ago
                      Getting some work done on my truck
