3.4 camshafts? - FirebirdV6.com/CamaroV6.com Message Board
3.4 camshafts?
  • 3.4 camshafts?
    Im looking for a new, performance oriented camshaft. Who makes one for he 3.4? Crane? Comp?
    What durations/lift specs should I look for? I am wanting to retain driveability without losing too much mileage. A decent idle is desired,but something with a little more rumble than stock. What kind of HP/torque gains are people getting from the different cams? Prices? IS it good to get new rockers with the cam change? Roller rockers?
    Thanks.
    1979 Z28 Camaro, 1 of 10,000 Factory 4 speeds. <br />1994 Camaro Sport Coupe, M5<br />Best ET: 15.31@91.5 (25 hp NOS)
    http://www.crower.com/misc/m_cat.shtml
    the hydralic-hualer is a pretty gnarly cam :D
      there is more info in this post
      http://www.camarov6.com/cgi-bin/ulti...16&t=000020&p=
      :D [img]graemlins/toto.gif[/img]
        There aren't any cams out there for the 3.4 that will work with SFI. So unless you have some other way to do fuel management there isn't a whole lot of choice.
        83 S-10 w/95 3.4 SFI, 4L60E
          There is one for the 3.4 it's comp cam grind 2150 for the cars that have a cam sensor
          however if you have a cam sensor some cars do some don't you need to have one custom gorund you can do this by sending them yours and having one ground it's liek $198 total and there's put the devation for the cam sensor
          My new ride 2000 camaro, No mods yet still waiting for warranty to run out then all out heads, cam, and supercharger
