valve orientation, quick question - FirebirdV6.com/CamaroV6.com Message Board
  • valve orientation, quick question
    Ok, with engine in car, looking at the heads with the exhaust manifolds facing you, from left to right where are the intake and exhaust valves located in each cylinder? Thanks.
    Brendan
    2000 Camaro L36 M49
    I am a man, I can change... if I have to.... I guess.....<br /><br />-Red Green
    Just look at the exhaust manifolds, and the intake runners. The valves will be directly above/below them.
      The bigger valves are intakes and the smaller ones are exhaust.
        yea 2 valves per cylinder, the bigger one is the intake
        1997 camaro rs<br />1989 TURBO SUPRA w/ sp61gt
          <blockquote>quote:</font><hr>Originally posted by oil pan 4:
          The bigger valves are intakes and the smaller ones are exhaust.<hr></blockquote>
          with the engine in the car he wont be able to see the underside of the heads though [img]graemlins/slap.gif[/img]
          -Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
