Cam ? - FirebirdV6.com/CamaroV6.com Message Board
Cam ?
  • Cam ?
    Comp cams told me to get this cam. Let me know if its good. I want more hp but I don't want rough idle. My car is a daily driver. When I put the cam in ill have full 3 inch exhaust headers. Also will have slp CAI and whisper lid.
    The 76-801-9 has an RPM Operating Range of 1000-5500. You need Intake improvements & must replace the valve springs. Take a look at the specs & let me know what you think.
    Thanks, Darrel Miles
    Cam Spec Card Inquiry
    PART NO. 76-801-9
    01 INTAKE MASTER 3105S
    02 EXHAUST MASTER 3106S
    03 ENGINE GM38 255HR12
    04 GRIND NUMBER GM38 255HR12
    INT EXH
    05 HYDRAULIC Y/N YES 14 DUR @.050 201 205
    INTAKE EXHAUST 15 LOBE LIFT .3120 .3000
    06 VALVE ADJUSTMENT HYD HYD 16 ROCKER RATIO .00 .00
    07 MAX GROSS VALVE LIFT .517 .498
    08 DUR @ .006 TAPPET LIFT 255 262 17 LOBE SEPARATI 112.0
    18 ADVANCE 4
    09 VALVE TIMING OPEN CLOSE 19 VALVE SPRINGS
    @ .006 10 INT 7- 27
    11 EXH 38 13- DATE SETUP 11/19/2002
    12 THESE SPECS ARE FOR CAM(S) INSTALLED
    @ 108.0 INTAKE CENTERLINE
    13 REMARKS
    Thats want comp cam sent me in my email. I have no clue on cams. Ive been reading but not much help. Also tell me what cam you would use for what I want.
    2001 Sunset orange Firebird! Gone!<br /> <a href=\"http://www.cardomain.com/memberpage/478082\" target=\"_blank\">http://www.cardomain.com/memberpage/478082</a> <br />Whisper lid,SLP CIA,FLowmasterexhaust.
    So thats a 201/205 .517/.498 with a 112 lobe seperation? Thats a odd cam, nothing i have seen before... I will let the other cam guru's help ya with that, but i think you might want to get somthing else...
      112 ls that sounds like it would chop to hell and back, i dont think that will idle smooth like you want
        Definately will not idle smooth. Widen out the LSA to 116 and go with more lift, like 212/212. Our engines don't need a split duration, that's more of a LS1 or forced induction thing.
          no, won't idle smoothly, i've got 111 LS, is choppy, but has never stalled yet, even with a/c on.
          i agree about the split duration too....if you're gonna keep it n/a, i'd personally go for same duration on intake/exhaust.
          --matt
            I have that cam. It is a variation of the controversial 200/206 grind.
            I have put 1500 miles on mine so far. It has thrown the SES light once for a P0300 random misfire. It never did it again.
            It pulls hard right up to the redline. I want to get my rev limiter raised to see how much higher it will go. It still makes plenty of power past 5500 rpm.
            It is streetable and docile at lower rpm. It does lope a fair amount at idle, but only when the engine is at operating temp. It sounds really cool.
            It likes to generate heat. If I leave the car idling, it will get hot way faster than the stock cam. It never gets close to overheating though, so don't let that scare you. A 160 deg thermo is a good compliment. This cam likes cold.
            I have the stock valve springs on still. They haven't broken yet, but they chatter. I am going to replace them soon.
            1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
