well, my car was running like a real brute until one day it started sputtering, and missing while cruising @ 45. i threw some fuel innjector cleaner in it, but nothing happened. the problem got worse, and i replaced the wires and plugs, bosch wires, and delco plugs, and problem got better a little. i recently put used accells,(3,000 miles old) on my car about 2 months ago. MY QUESTION IS THAT I HAVE HEARD THAT ACCELLS GO BAD FROM THE HEAT AND CAUSE MISFIRES, BUT IF THEY TEST 7-8 OHMS CAN THEY STILL BE BAD AND CAUSING MISFIRES? THIS IS THE ONLY THING I SEE THAT I CHANGED, OTHERWISE I FEAR A BLOWN HEAD GASKET,BUT NOT SURE WHY? PLEASE HELP ASAP
Car misfiring, sputtering, and running rough!!
Same thing was happening to me, all I did was change the fuel filter and it runs beautifuly again :)\'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
found it!!!!! Although i was embarrasd to post, ANSWER- upon completeing my last oil change, my father who was giving me a hand put 5 quarts of oil instead of the 4.3 qts that the Haynes manual suggests, and the engine was choking. now there is no more purple smoke upon start, ( which scared me into thinking possible head gasket) thanks everyone for their help.
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...8 hours ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....4 days ago
