I'm currently painting my calipers today and I'm having a hard time. I can't seem to get the paint to stick without running. I cleaned the hell out of them, but apparently not good enough. Would this be the reason the paint won't stick, they're simply not clean enough? I'm using engine paint (500 degrees) with ceramic. I asked around and everyone said it's the same as the caliper paint they sell. Any suggestions for drying better and not running???
Hard time painting calipers
Thinner coats my friend, your probably spraying them entirely to much. It usually takes 3-4 coats, then a final spray of clear coat to get them nice. Good luck [img]smile.gif[/img]This revelation, is the death of ignorance...<br /><a href=\"http://www.quicktimeperformance.com\" target=\"_blank\">www.quicktimeperformance.com</a>
Try using a high temp primer to help thje paint adhere.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
If you've got a sander use it with the metal wire attachment ..i ve done it with that and the wire brush the wire brush doesnt get them as clean and it takes alot longer. If they paint is still running try sprayin onto paper then using a brush and painting it on it actually works nicely and isnt very messy- Why tiptoe through life to arrive safely at death -
I used a wire brush thing and got all the rust off until the metal was showing then cleaned them with soap and water and then put 4 thin coats and then one thicker coat and I never had any problems with the paint running.
BEFORE AND AFTER1995 Firebird 3.4 V6 M5<br />-Firehawk 17x9 w/275/40/ZR17, flowmaster 80s, high-flow cat<br />*new* BMR lowering springs, Bilstein shocks, WS.6 sway bars, polyurethane bushings.
Very slowly. I had the day off from work so I taped off like the whole car and played basketball with my brother in between coats. I did use alot of paper towels to stuff in the side of the caliper, where you can see the edge of the rotor. Used grocery bags too.
Here's a picture of the car covered and everything taped up and ready for spraying.
Here's a picture of them afterwards in the garage. Not good lighting though. Dang I want a rear-end conversion to discs.
Any other questions just ask.
Good luck and take your time. Better safe then sorry.
Travis.1995 Firebird 3.4 V6 M5<br />-Firehawk 17x9 w/275/40/ZR17, flowmaster 80s, high-flow cat<br />*new* BMR lowering springs, Bilstein shocks, WS.6 sway bars, polyurethane bushings.
Travis.
150 for rear disk converion ;) include caliper Ebrake cables and rotors mounting brackets too check it out ;)www.turbov6camaro.com
1997 3800 Series II Camaro
