How do you do this? I don't think you can take them off....so I'm not sure how?? Anyone?
How To Paint Brake Calipers
2002 Black FireBird M5 2-5-02<br />Red BMR strut bar<br />Dynomax Super Turbo muffler with FastToys.com tips.<br />4 Coats of Zaino - Better every time<p>Need to post pictures? Do it <a href=\"http://www.thenebula.com/carpics/\" target=\"_blank\">here</a>. its <b>easy</b> and <b>free</b>.<br />Change your own oil. <a href=\"http://www.thenebula.com/firebird/oil/\" target=\"_blank\">click here</a>.
I would take the entire caliper off the rotor and hang it with safetywire or a coat hanger and paint it. Then put it all back together after it dries. I hate to see painted pads. :mad: If you paint just the calipers and mount plates then it should look pretty good. [img]graemlins/thumbsup.gif[/img]\" As being is to becoming, so is pure itellect to opinion, so is science to belief, and understanding to the peception of shadows.\" - Plato
My caliper & drum painting experience is that if you paint the calipers/drums only once or twice with high heat paint, they tend to heat and partially burn off here and there.... so it is a great idea to paint it at least 3 times, and then apply an even higher temp clear coat at least once..
I painted my rear drums twice originally and noticed that the paint on the edge of the drum came off a little bit, so I took it off and repainted the things again but this time 2 more times, and now its all fine. The painted drums also had a burnt paint smell effect after the initial paint process, this took a couple of days to go away and now there is no smell.
I will be painting my calipers as well (making sure I apply 3 coats of black, and 1 coat of clear), as soon as my caliper metal decals arrive...
here is a pic of the decals that is a great addition to any caliper (makes it look great...)
Hope this info helps you a little more [img]smile.gif[/img]
Paint them before you take the pads off so that when you swap pads you have normal looking pads behind the painted calipers.
I, too, hate painted pads.2002 5-spd NBM Camaro
Details: www.1lev6.com
Decals: http://firebatscave.deeztech.com\firebird.hml
As for painting, I didn't use high temp paint and I opted to paint with a brush instead of aerosol to control the overspray. I also sanded the surface with my dremel. Sorry no pics,Zaino; FireBatCave Decals; Red Inside<br /><br />K&N Filter & Lid; Removed MAF screen; FRA; Raised Air Box; 180°F Stat; BMR STB; 3\" Catco & S-pipe; Borla Cat-Back; O2 Sim; HPPIII; NGK TR55s; Taylor 8mm wires<br /><br /> <a href=\"http://www.cardomain.com/id/cbass300\" target=\"_blank\">http://www.cardomain.com/id/cbass300</a>
Paint the caliper when the pads are off and the caliper is hanging there.(Use safetywire or a coat hangar to prevent stress on the brake lines)\" As being is to becoming, so is pure itellect to opinion, so is science to belief, and understanding to the peception of shadows.\" - Plato
thabomb180 : http://store.yahoo.com/afterthoughts...rakcaldec.html
20USD for two, includes shipping, made outta metal... great deal
