what exactly r ghost flames? - FirebirdV6.com/CamaroV6.com Message Board
  • what exactly r ghost flames?
    what r ghost flames and i want to get flames on my 98 firebird its chameleon blue green should i
    get ghost flames or regular flames and wut color should the flames be.thanks in advance.pics r appreciated
    "Ghost" or "Phantom" flames are flames that are painted on the car with a color that is very similar to that of the car itself. The flames are hard to spot (hence the name) but look very cool when you see them.
    1997 Dodge Viper GTS
      <blockquote>quote:</font><hr>Originally posted by AZ3.8Camaro:
      "Ghost" or "Phantom" flames are flames that are painted on the car with a color that is very similar to that of the car itself. The flames are hard to spot (hence the name) but look very cool when you see them.<hr></blockquote>
      Ehhh, not 100% correct. I have seen ghost flames that are a completely different color than the car. The trick is viewing angle. The flames are painted on VERY softly and often with "pearl" colors. The "pearl" is the trick to the whole "ghost" flames. The pearl paint can be completely see thru at one angle and then at another be nearly opaque. thats more how it works.
      2002 Maple Red Firebird V6<br />3.73 w/ LSD | Pro-5.0 Shifter | Fan Switch | Tach w/ Shiftlite | Boost and Fuel Pressure Gauge | Bilstein Shocks & 1LE Springs | 1LE 32mm Bar & Poly Bushings, Poly Tranny Mount and Torque Arm Bushing | BMR LCA\'s | Catco 3\" Cat w/ Edlebrock 5509 Muffler, (all 3\") | Corbeau A4 Seats (Pair) |<p><a href=\"http://forums.fakeleg.com/\" target=\"_blank\">http://forums.fakeleg.com</a><br /><a href=\"http://cv6.fakeleg.com/\" target=\"_blank\">http://cv6.fakeleg.com</a> - Part & Repair Manuals and write-ups.
        Ghost flames are awesome! Go with those!
        Derek <br /><a href=\"http://www.cardomain.com/id/dmiller_2005\" target=\"_blank\">2002 Metallic Silver Camaro</a><br />35th Anniversary
          Heres a good example - theres this guy who lives in my area that has a early 4th gen Trans Am. Its black and it has really deep purple flames on it. If you just glance at it then you probably wouldnt notice but when you accually look at it, especially from a certain angle, it looks soooo amazing. Often cars with ghost flames only have the outer edges of the flames painted, ie the front of the car is the same color as the rest of the car, if that makes any sense.
          <b>Black 1996 3.8L Firebird A4</b><br />--------------------------<br />Custom CAI, Flowmaster Dual Exhaust, 160 Deg Thermo, BMR ShockTower Brace<br />JVC mp3 HU, two 12\" Infinity Kappa Perfects, Infinity 6.5\" components, JBL 600.1 & 80.4 amps <br /><a href=\"http://community.webshots.com/album/479229363CPbPiz\" target=\"_blank\">Pics</a>
            Screw it ill just post some pics. Enjoy!
              Still trying to find oil leak
              1 day ago
              Getting some work done on my truck
