A little advice? - FirebirdV6.com/CamaroV6.com Message Board
A little advice?
  • A little advice?
    Well, my drivers side door stopped working a while ago (just the outside) - The rod which hooks into the handle fell out. I can get it back in the hole, the problem is after a few door closes it falls out...SO....I need something i can put on the other side to hold it in place (similar to the way you would use a nut on the other side of a screw) , but can't really get my hands down there to screw anything on, nor is there any thread anyway...so im thinking some sort of adhesive or something...like gorilla glue?
    I was just wondering if anyone had any suggestions? Any help would be much appreciated I would like to use my driver side handle on the outside!
    <b>Red 96 3.8 Liter Camaro</b><br />SLP Cold Air Intake<br />Flowmaster Exhaust<br />2 12\" Pioneer Subs in a custom box<br />900 Watt Rockford Fosgate<br />Kenwood Deck<br />new engine at 102k!<br /> <a href=\"http://www.cardomain.com/id/red38fbod96\" target=\"_blank\">http://www.cardomain.com/id/red38fbod96</a>
    Re: A little advice?
    isn't there a clip that is broken? those clips probably do not cost more than a quarter
    2000 3.8 A4 Pewter Camaro
      Yeah it's a clip, and it costs $.79 big pennies.
      Or if you can find a way to get a soldering knife back there, you could solder it together and that would work sufficiently.
        I dont think this should be in Appearance
          Where could I find this clip?
            Still trying to find oil leak
            1 day ago
            Getting some work done on my truck
