anybody replaced the head liner in a 4th gen? if so is it hard?
head liner replacement
Re: head liner replacement
its easy, take the visors off (3screws each) take the dome light off, and if you have a t-top car there is a little push pop plastic thing in the middle.
That's about it
what meatyshells said plus the little retainers where the ttops lock in.
its fairly easy, slighty time consuming. but you HAVE TO be EXTREMELY carful because the middle part where its skinny is very weak and notorious for breaking.
i did the and now i have a crease in the middle :(
i recommend getting and ABS plastic headliner if you are removing the stock one. thatll make it a 10 min job,
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...7 hours ago
