Can someone tell me if the voltage regulators on our cards are internal to the alternator or external? If they are external where exactly? The haynes manual makes no mention of it and I couldn't find it as a replacement part at advance or autozone. It's a 2000. TIA
Voltage Regulator
Re: Voltage Regulator
You can buy a Caspers Voltage Booster, mine ups the voltage 1.2 volts after 70% throttle it connects to the TPS and the ALT. , so I run around 13.3 and it goes to around 14.5, this is with a 10LB Dynabatt up front and a Optima Batt. in the rear.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by youngsc View PostCan someone tell me if the voltage regulators on our cards are internal to the alternator or external? If they are external where exactly? The haynes manual makes no mention of it and I couldn't find it as a replacement part at advance or autozone. It's a 2000. TIA
Originally posted by ssms5411 View PostYou can buy a Caspers Voltage Booster, mine ups the voltage 1.2 volts after 70% throttle it connects to the TPS and the ALT. , so I run around 13.3 and it goes to around 14.5, this is with a 10LB Dynabatt up front and a Optima Batt. in the rear.Let's flip a coin. Heads I get tail, Tails I get head.
If your ALt. is fine you could try the big 3 wire mods putting a 4ga. from the alt. to the batt., like a 2ga. from the batt to block neg wiring, and a 4 or 2 ga from pos. side batt to the acessory box. Should help some if not your Alt. is screwed.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostIf your ALt. is fine you could try the big 3 wire mods putting a 4ga. from the alt. to the batt., like a 2ga. from the batt to block neg wiring, and a 4 or 2 ga from pos. side batt to the acessory box. Should help some if not your Alt. is screwed.Let's flip a coin. Heads I get tail, Tails I get head.
Truth hurts sometimes. LOL08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
