Passenger Side Headlight wont rise sometimes - FirebirdV6.com/CamaroV6.com Message Board
  • Passenger Side Headlight wont rise sometimes
    I've replaced the Nylon gear with the Brass Gears in my 02 Firebird and I also purchased a brace off of Ebay to hold the cap in place because the passenger side one had a very hard time staying in place..
    The ebay link
    http://cgi.ebay.com/ebaymotors/1993-...Q5fAccessories
    On my passenger side headlight, the one with the brace in place... SOMETIMES, and not always, when I activate the headlights, only drivers side rises but the passenger side doesnt budge. Turn them off and turn them on again, same thing... and keep doing it about 5 times and it will finally come up. It always goes down just fine, no grinding or anything. I've noticed it usually happens after its been sitting during a long rain. Rust??? After they raise up once, you can turn them off and reactivate them and they'll work fine... What gives here?
    Re: Passenger Side Headlight wont rise sometimes
    Brass doesn't rust. I would pull the motor and check the epoxy all the way around. If it only happens when it rains, perhaps you plug isnt plugged in all the way and its wet.
    Rick
