tail light bulb issue... - FirebirdV6.com/CamaroV6.com Message Board
  • tail light bulb issue...
    Not on my car but on my friends 01 z28. His outer 194 bulbs were blown out so I replaced them for him. Worked. And the next day both were burnt out again. Any ideas?
    #1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
    Re: tail light bulb issue...
    Are the marker lights or license plate light having any problems? Based on the Hayne's wiring diagram, there is no reason the 194s in the tail lights should be getting any more power than any of the other tail lights.
    1996 Chevrolet Camaro
    1995 Buick Park Avenue Ultra
    --Appearance Moderator--
      same was happening to me what i did was remove the bulb and clean the inside of the socket with some rubbing alcohol to remove the corrosion and its been fine since
        ^^ That was my only thought; that the sockets could be the problem. It seems a bit strange that both would begin doing the same thing at the same time, but it's worth a shot.
          It def fixed my problem...mine was only the drivers side going out btw
            Mine don't burn out....I just have one side that is dimmer than the other.
            2002 Camaro Convertible - Stock!
              sockets or water in the housing
                5 days ago
