Basically what it says.. I ran 4ga from alt to battery and battery to ground... nothing else. I'm confused.
Low volts after big 3
Re: Low volts after big 3
UPDATE:
It died on me driving 11 miles home from a friend's house. Consistently dropped volts, and died just as I pulled up to my house. On the way, obviously, lights dimmed, etc. I shut off the stereo, that didn't help. Lovely as it is, I got ABS INOP, Service Vehicle, Security, Check Gauges, Airbag, and Brake lights on the dash.
Am I correct to assume I have either a ****ed up wire, or my battery is shot? The Battery is being tested tomorrow morning IF I CAN. And I'm going to check the wires when it's light out. It acted like it wasn't getting a charge from the alt, which is less than 10k miles old.
I should also note that it chugged pretty damn hard for the last miles or so getting there. All gauges went dark, headlights were nearly off, and I was floored in 1st gear going maybe 10. I am REALLY hoping for an easy cable or battery fix... but just to mock me it has enough power to flash the security light on the dash.Last edited by Docta; 08-08-2011, 02:17 AM.
Originally posted by Docta View PostBasically what it says.. I ran 4ga from alt to battery and battery to ground... nothing else. I'm confused.
.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Originally posted by Docta View PostOkay. Well now that my dumb moment is gone, I'm getting nearly 18v. I didn't tighten down the connector from the alt to battery.:slap:08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by Docta View PostWell the battery was shot. Got a red top now, and its still not charging right. But what do you mean the positive terminal? I thought that was the red one on the battery..
Raven
Originally posted by bigairboarder44 View PostThe alternator picture and two engine pictures above it aren't showing up, fyi.
Raven
