Opening door panel for speakers - FirebirdV6.com/CamaroV6.com Message Board
  • Opening door panel for speakers
    Is there a website that tells how to replace the factory speakers? I know you have to open the door panel but i'm not sure on what all needs to be taken off. Websites?
    <a href=\"http://www.xbox3604free.com/default.aspx?r=381546\" target=\"_blank\">http://www.xbox3604free.com/default.aspx?r=381546</a>
    Go to this link http://home.swbell.net/shoebox/windowmotor.html
    which will show you pretty much how to remove the door panel. Once the panel is off, just take the inner door panel plastic off (carefully so you can reuse it and then there are just four screws that hold the speaker to the door. Disconnect the speaker wire and voila you are finished. Reassembly is simply the reverse of disassembly.
