WORST INSTALL EVER!!! - FirebirdV6.com/CamaroV6.com Message Board
  • WORST INSTALL EVER!!!
    well my plans were as follow:
    install new window motor
    install ed components, mids/highs
    dynamat just around speakers etc
    install cold cathode tubes
    build amp rack
    this is what happened
    installed all speakers, had to build custom speaker rings for rear, and a whole speaker set for up front, then installed dynamat, then installed speaker, oh before i done all this i replaced the windo motor on pass. side,(not to to bad, just had to find everything) then started wiring up everything, wired it all up, and something was wrong! i had major frequecy/static, so i traced it all the way back to the ground, regrounded it and all is good right? for about 1 min, so i start messin with the gain and can turn up the front up high, i touched the back ones to turn them up and amp shut off, well long story short, after about 2 hours i find out that it is my rear, voice coil hitting the dynamat( pos and neg touching dynamat) therefore grounding out! i then fix that and bamm!!! another problem all of a sudden i have major noise in the speakers(power ant. goes up i can hear it etc) so after trying numerous things my neighbor gives me these things to put on my rcas! and bamm it all works!! now i have to put car bak together, BUT i have yet to install my cathode lights, or build my amp rack!!!
    EEGHH what a few days!!!
    lol good story. what did your neighbor put in the RCA lines? ive heard of putting something in the battery cable before..
    Dave:
    00 Supercharged Camaro - RIP
    97 Turbo Camaro - Sold
      haha glad to see you got it together! what do you think of the comps? you got the 6000's right? what amp are you using?
        ground loop isolatar? on the RCA cables?
          just curious,what kind of wiring did you go with?
            all sringer wiring and yes i think it is a ground loop isolator
              What is cathode lights?
              *Matt
