Can i mount my amp here? - FirebirdV6.com/CamaroV6.com Message Board
  • Can i mount my amp here?
    Can i mount my amp here.... of course ill fix up all the wires i just disconnected some of them to take the pic. i think it would be a cheap and easy solution.
    \"Well, we don\'t care how bad-*** some dude\'s N/A Honda S2000 motor is; if you go up against 900+ pushrod ponies and 750 pounds of earth-shaking torque with a wrong-wheel-drive econobox, you\'re gonna get a fast and furious old-school ***-whipping.\"
    yes, if you never flip the cover over.
    if you think you can mount it there, then flip it over.. your going to run into cooling issues, as the heatsinks are designed not to be upside down
    Ryan
    1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
      i am only going to flip it closed when the car is parked so the amp is not seen... for security.
      sound good?
        are you really going to flip it every time you drive?
        also, when you "flip it for security" you have already opened your trunk, and anybody can see what you have ;)
        I would reccomend a white rascal style amp rack, on the back of the t-top well.
        That is what i run.
        Ryan.
          it would be fine upside down at all times... there is enough air under it to keep it cool enough... it wont get hot anywayz
          CaLi<br />-=|Sinister Six|=-<br /><a href=\"http://www.villagephotos.com/pubbrowse.asp?selected=756425\" target=\"_blank\">1999 Chevy Camaro Pewter</a><br />Have you ever wanted to know what happens<br />to a 3.8l v6 when you are doing 90mph in <br />2nd gear at 6000 rpm? pics to come soon...
            <blockquote>quote:</font><hr>Originally posted by CaLiJeRk:
            it wont get hot anywayz<hr></blockquote>
            i dunno bout that, i have it right now sittin at the bottom of the ttop storage and when i had that lid closed and ran that amp for mayb 1-2hrs it was hot enough to cause burns. and yes i would close it everytime i drive.
              it would be fine upside down at all times... there is enough air under it to keep it cool enough... it wont get hot anywayz<hr></blockquote>
              amps state in the owners manual, do not mount inverse, due to the design of the heatsinks.
              I have 2 amps in my t-top well, no problems with heat. i have installed a 1200 watt kicker, and no problems with heat back there.
              but both are mounted where they can breath a little, in that area. and vertical, not inversed.
              Ryan
                so i should be fine as long as i flip it open when in use?
                [ February 11, 2004: Message edited by: kamarozrule ]</p>
                  nm guys i decided on not mounting it ther... i forgot all about fbodyaudio.com so i went over there and Cliff_J poined out that "What happens if you get in a frontal collision - you've got a 20lb projectile traveling at 60MPH to the back of your head unless the wires can stop it...."
                  and Ted_J hooked me up with this sweet link http://www.fbodyaudio.com/cgi-bin/ya...num=1072017862 it shows how to mount a amp rack to the rear wall, i was puzzled on how to do it, now im good to go and thats how ill be mounting this amp. thankz for ur input guyz.
