MP3 player and the factory 12 disk changer - FirebirdV6.com/CamaroV6.com Message Board
  • MP3 player and the factory 12 disk changer
    Ok so I have the DELCO 10 speaker system with a 12 disk factory cd changer and Im about to get this mp3 player...is their a way to have them both connected? Im thinking to just use the tape adapter but Im not sure how clear it is? ANy help Thanks.
    1996 Firebird-Y87:SLP Cold Air Intake,Y87 Perf. Package: 3.42 Gears w/ Zexel-Torsen LSD, Sport Steering(14.4:1 ratio), Dual Exit Exhaust,800 watt Pioneer Amp and Two 10\' subs with a custom trunk enclosure.
    anyone?
      I do believe that an FM modulator can hook up anything to any stereo. Should be like 15 bucks.
      Red 96' A4 Firebird
      Audio Audio and Autotek
      Check it out here!
        If your "factory cassette deck" controls a "factory cd-changer", a GM9-AUX will work. The device gives you a pair of RCA inputs. Not sure if you can have them both plugged in and choose between either the cd-changer or the mp3-player. I'd email the company and see.
        2006 Tiburon
          Does that FM modulator use a low frequency station to use the radio....is thislike a wireless one because those suck @ss...static like crazy......
            Yeah, don't get the FM modulator, it'll sound somewhere between AM and FM. It's got bad frequency response and you'll probably get static most of the time.
            Yes, I know \"Artic\" should be spelled \"Arctic\". Can any of the mods change this?
              Well since this doesnt seem to be possible does anyone know if the tape setup sounds good?Scratchy at all?
                it'll sound okay but you'll get the hiss noise like you would a regular cassette tape.
                  If you're looking for the best possible sound, either use the gm9-aux adaptor, or replace the factory stereo with an Aftermarket CD-player with RCA inputs.
                  2006 Tiburon
                    yea but I already have a 12 disk changer...will the gm9 aux adapter work with this?
                      Like I say, I don't know if you can have both the mp3 player and your factory cd-changer all hooked up together at the same time using the gm9-aux. It "may" just be one or the other. Email the company and find out. good luck
                      2006 Tiburon
