does anyone know wich wire is the tach wire off the pcm? i know for the 2000 V8 camaro its pin 10 on the bottom part of the pcm. please help me out, i need the exact wire color,my shift light has been sitting in my car for 2 weeks not completed, thanks guys
Shift light install
pin 54 on the blue connecter closest to the firewall on the passenger side of the engine bay is the correct tach lead. I was never able to find the white one in the inside.2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
i went out there and looked, the connector closest to the firewall, your talking about out of the three connectors? because i dont see any blue wire, if its the connectors im thinking off, its in ABC not numbers.2000 3.8 Camaro M5<br /><br /> <a href=\"http://www.cardomain.com/ride/832316\" target=\"_blank\">http://www.cardomain.com/ride/832316</a>
pin 54 on the blue connecter closest to the firewall on the passenger side of the engine bay is the correct tach lead. I was never able to find the white one in the inside.<a href=\"http://cardomain.com/id/articacid\" target=\"_blank\">2002 35th Anniv. Black Camaro M5</a><br />Mods: Carsound Cat, SLP Loudmouth, Whisper Lid w/ K&N, J&M LCA\'s, ST Springs, eD Stereo(146.7 dB)<br />\'88 K1500 305 V8 Auto(Winter)
now im told its behind the gauges , a white wire, does any body know wich wire it is exactly and exactly where it is? because i was also told pin 54 on the pcm, well the color they said, blue was pin 34 for mine, please help me out guys2000 3.8 Camaro M5<br /><br /> <a href=\"http://www.cardomain.com/ride/832316\" target=\"_blank\">http://www.cardomain.com/ride/832316</a>
i am also wondering my self my tach isnt complete ether2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
this isn't the best forum for this...
this forum is mainly for exterior appearance stuff...
better off with
Gen tech
drag racing
or electronics..-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
i think it is actually the white wire coming out of the pcm. i could never find the one inside the car and couldnt figure how to get to the one behind the gauges.<a href=\"http://cardomain.com/id/articacid\" target=\"_blank\">2002 35th Anniv. Black Camaro M5</a><br />Mods: Carsound Cat, SLP Loudmouth, Whisper Lid w/ K&N, J&M LCA\'s, ST Springs, eD Stereo(146.7 dB)<br />\'88 K1500 305 V8 Auto(Winter)
