Question about ground loop isolator - FirebirdV6.com/CamaroV6.com Message Board
  • Question about ground loop isolator
    So I'm powering my speakers with a 4-channel 600 watt amp and I have some alternator noise. If I were to get a ground loop isolator, I would have to get two of them; one for the front and one for the rear outputs on my HU right?
    \'96 M5 Camaro White<br />Flowmaster Full Catback<br />SLP CAI<br />180* Thermo<br /><br />Stereo: H/U - Clarion DXZ725 <br />Alipne Type-R 6.5 Components (front), <br />Alpine Alpine SPS-1629S 6.5 <br />2 10\" JL 10w0<br /><br />\"One Love\" -Bob Marley
    Yep.
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      did you run your power wire and your rca's down the same side?
        No I didn't... the RCA's are running alon the top trip of the door and the power is running along the carpt. I'm just gonna go pick a couple up today and see how they work. Thanks for the help guys.
          make sure your ground is nice and tight. And beure you sanded down the area down to the bare metal where ever it is you grounded.
            Where is a good place to ground my amps? I grounded it on that mount that holds the trunk clap thing right underneath the carpet.
              double check the grounds, and if necessary, run a ground wire from the deck to the amps, to your main ground, to make sure they are all on the same ground plane.
              I had to do that once, don't know why, i tested everything else, messed with the 0-scope for hours, and that finally fixed it.
              Ryan.
              1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
