How many wat amp? - FirebirdV6.com/CamaroV6.com Message Board
How many wat amp?
  • How many wat amp?
    So i have 2 12inch alpine type s, some guy offered me a kenwood amp for very cheap, the only problem is that it is 800w. Is that enough to power those subs well? What kind of wat rating should i be looking for to power these subs?
    2002 M5 camaro- VTR CAI, custom cat-back exhaust, battery compacitor, pullie, lowering springs, 32mm sway bar, cross-drilled slotted rotars. 1-10\" L7 in cubby.
    We need to know more about then amp. You have a model number? Maybe thats 800W MAX. Or maybe RMS? At 2 ohms? 4 ohms? I would recommend atleast 600WRMS for the pair.
    Red 96' A4 Firebird
    Audio Audio and Autotek
    Check it out here!
      Here is what i know about the amp
      150x4 at 4 ohms
      400x1 at 4 ohms
      That wont be enough to power those two alpine type s 12s will it?
        ok ok. This is a 4-channel amp you want to run in bridged mode. Now, I can guarantee you that this amp will not run at 2 ohms when bridged to a single channel. Meaning you are dealing with a 400W amp my friend. Unless he is giving you a smokin deal on it.....I'd pass it up. How much you looking to spend for your new amp?
        Red 96' A4 Firebird
        Check it out here!
          Well i got the two alpine type-s 12s, and that amp for 300 shipped. I can re-sale the amp and get a new one, all of the stuff was brand new in the box. What is a good amp that you would use to power these two subs or should i just buy 2 seperate ones.
            Ouch. Well..... I'd use the Kenwood as it was intended and power four of my 6.75"s. Are all your speakers still stock? You don't have monsoon do you? The JBL BP600.1 will give you 600WRMSx1@1 or 2 ohms. Great buy for the money.
            Red 96' A4 Firebird
            Check it out here!
              What is the ouch? Are you saying that i overpaid? Well yes i do have the monsoon, so wouldnt it be a waist to use it as a speaker amp, and yes all of my speackers are stock for now. Is that amp good for 2 subs?
                Yes. That is a tad much. You can get the Type-s's for $120 a pair. Can't say I know what the amp goes for, but anyway.... what is the impedence of your voice coils. On the subs. 2 ohm? Dual 2 ohm? If you can wire each one to 4 ohms, you can bridge 2-channels together and power each sub off 2-channels. If you don't think that's gonna be enough power, sell the Kenwood and buy the JBL. Yes, the JBL will power both subwoofers.
                Red 96' A4 Firebird
                Check it out here!
                  Yeah so in the intrest of keeping my t-top i sold one of my 12s. So i am going to buy the 12inch pasanger side cubby box and use my amp for just one sub, that will be enough power for 1 sub right?
                  Is my bass going to sound uneven with a 12 on just one side of the car?
                    Or should i sell it and buy something else, what is a good 1 or 2 channel amp that could power a 12inch alpine type s and be around 150 used?
                      the jbl 300.1 will power your one sub
                      your bass will sound fine and full. low frequencies are not directional.
                      for around 200 shipped off ebay get the 600.1 so you can upgrade later if you decide to.
                      good luck whatever you do
                      A4 :( ws6 hood, magnaflow cat-back, Pewter ppg paint, red calipers w/ decals, t-tops, chrome wheels, cutout, bald rear right tire (3.42 w/o lsd)
