Do any camaros have steering wheel controls for the stereo?? I'd like to install a steering wheel control but ive only seen em on Birds.... If i found a steering wheel, would I be able to integrate it with my alpine deck?
Steering wheel buttons for stereo
If you're deck has a remote control, you should be able to hook up the steering wheel controls to it. Check the Modifications Encyclopedia.<b><i>Don\'t Ever Judge Me</i></b><br /><a href=\"http://www.cardomain.com/id/earnhardt132000\" target=\"_blank\">\'96 Firebird Y87 3.8L V6 5spd</a><br />--No mods as of yet, shoot me some ideas if ya want.<br />178,000 miles and counting
no, hes saying his current steering wheel does not have wheel controls, and he would like to replace it with a steering wheel that has them.
It would work if you could get the wiring to gyro correctly, i don't know how the birds are hooked up tho.1996 Pontiac Firebird<br />Flowmaster Exhaust, Custom Cold Air Intake, 3.42 gears with LSD
all you will need is a 2000+ camaro steering wheel I got one for $50 off of ebay with the wiring harness. Then you will need an airbag out of one. The 96-99 monte carlos are the same also. Then it is a 4 wire connection. ground, switched power, dash light switch, and then the signal wire. To hook it in to the headunit you will need a pac swi-x they run you about $50 on ebay. I installed them in my 2000 camaro and it took about 2 hours to do and then I also put some in my 95 jimmy and am changing the bag to the new style. It will probably cost you about $200 to do it yourself depending on how much you can get the bag and wheel for. E-mail me if you want more info on it.2002 M5 Bright Metallic Silver <br />*Fully loaded and modded<br /><br />2005 GSXR 750<br />*Micron Serpent Race Exhaust *K&N Filter *Power Commander *Trying to hit 200 MPH!<br /><br />1970 SS 454 Chevelle Cortez Silver<br />*It can pass anything but a gas station
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...1 weeks ago
