i have an older jl 10w6 and the foam between the cone and the outiside of the sub is coming off. is there a way to replace it or have it redone? can i take it to an audio repair shop and they can re-foam it for me?
replacing foam surrounding on sub?
Re: replacing foam surrounding on sub?
i saw a refoam kit made for jl 10'' subs on ebay for 25 bucks so i bought it. anyone have any experiance with these?
i have talked to others that bought the refoam and they said it worked out great, which im happy because im not about to throw away an almost perfect jl w6 woofer
from what i have read you basicly just take off all the old foam remove the very outside gasket, clean that off, and then glue the new foam on. Then glue the gasket back on
