Who has solox in maro in here? Because I am very close to put it to geather in my car. :banana:
Solo-x
Re: Solo-x
Originally posted by PalmHarborBlkv6Is it a radar dectector ? I have a one, its a Valentine...its very good and has saved me from tickets here in Florida
If you want noise, its a great sub, but if you want anything that sounds half way near decent even, don't consider it. They require a **** ton of power, and you are going to need some very serious electrical system overhauls to get it to run right, and one big amp. Be prepared to dump a few grand, between amp/sub/box/electrical work and cables I would say at least a good $3000 if you do the work yourself.1995 Camaro 3.4 A4<br /><br />CAI,IAT Relocate
Re: Solo-x
Originally posted by junkey_chanwell that's what i wan just loude. and i might add one more 12 later on if i like what i get out of it.1995 Camaro 3.4 A4<br /><br />CAI,IAT Relocate
Re: Solo-x
Originally posted by junkey_chanwhat u suggest? rewiring? add capasitor? yellow top? i am thinking to add 2000 watts autotek or soundstream amp
As far as yellow top, at least 1, 250+ amps of alternator, new ground straps, and I would say closer to 5 farad capacitor for the 1 amp. Also be ready to buy 0-gauge power cables, rewire the new alternator.
That I would say would be a good start at making sure that amp runs properly. I would also probably use 8-10 gauge for speaker wires.1995 Camaro 3.4 A4<br /><br />CAI,IAT Relocate
Re: Solo-x
Power handling capability depends HIGHLY on the box design. I notice from the little drawing you posted, that you're planning to do a vented design. Size after sub and port displacement? Port length (tuning freq)?
I just removed my system from my bird. Two 15" L7's powered by 3kWRMS. I had Dominick from Irragi Alternator's build me my alt. Paid..... (been awhile).... $280 for it??? The key is to get the highest output AT IDLE possible. Make sure you know the idle output. End of story there.... yellow or red under the hood, doesn't matter unless you plan to bump it without the car running. Think red has a higher CCA rating..... anyway, then I used 0awg from the batt to the rear. Check out your local welding shop for that. Much cheaper and still really flexible stuff.
Those upgrades were all I had and did fine under normal listening conditions. It could bump a little.... but as soon as I started lettin it loose, voltage would drop WAYY down. With 2 Optimas, H/O alt and a couple farads of caps, you should have no problems even at high volume slammin!
Oh and I'm putting everything I had in my car up for sale. L7's are already sold. But I still have two like new Autotek XS1600X's if you're interested. Shoot me an email.Last edited by 96firebird311; 11-11-2006, 04:40 PM.
Re: Solo-x
i thought you had 2 adire audio subs?.. maybe its a typo but your sig says
''audio audio and autotek'' lol1999 Black Pontiac Firebird <br />2 Rockford Fosgate P312D4 subs <br />Hifonics Brutus 1205d amp<br />Clear Sidemarkers<br />18\" Arelli Jovan Chrome Wheels
Re: Solo-x
Originally posted by bret_xii thought you had 2 adire audio subs?.. maybe its a typo but your sig says
Re: Solo-x
ohh... are you going to keep any kind of subs or anything in your car?
i never got as into it as you but i'm already getting tired of it... i think just one 12 might be the way to go for me.. lol1999 Black Pontiac Firebird <br />2 Rockford Fosgate P312D4 subs <br />Hifonics Brutus 1205d amp<br />Clear Sidemarkers<br />18\" Arelli Jovan Chrome Wheels
