woofers for a 99 bird - FirebirdV6.com/CamaroV6.com Message Board
  • woofers for a 99 bird
    do you think these will do ok for the replacment of the duel voice coil speakers in the sail panel?
    http://www.walmart.com/catalog/produ...uct_id=4541646
    Re: woofers for a 99 bird
    i wouldn't buy anything from wal-mart nor would i buy any of the sony stuff. Look into Alpine, Infinity, Polk Audio, Pioneer. Those brands are kind of costly but you get what you pay for
      Those brands are by no means costly.
      And you want to replace the factory woofers with 3 tweeters basically? Because that's all you're buying in that link.
      Red 96' A4 Firebird
      Audio Audio and Autotek
      Check it out here!
        thats what i was wondering. i have infinity's in my truck and they sound great. there not that much eather. thanks
          Are you looking for some that are intended for bass frequencies? If you are you can check these out http://www.edesignaudio.com/edv2/pro...products_id=33 if you get the dual 4ohm version and wire it in parallel you will end up with a 2ohm load (like stock). The stock amp wont drive these perfectly but will work. Also you will need to do 1 of two things to get these to mount correctly, 1. You will need to get a spacer ring to keep the magnet from hitting the metal behind it or 2. just cut the metal behind it so it will fit. If you have a vert however you are stuck with stock, I haven't found anything that is slim enough to fit without hitting the linkage for the top when it is down.
            i have the same exact speakers in my car, and im happy with them. compared to all other stock-audio cars ive driven, my car sounds really good.
            1999 v6 Camaro M5
            Automatic to Manual converted
            Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
            !cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
              i have 2 10" JL W0s and they are amazing
                first off, I have to support the Sony Xplod line, I have owned a head unit, amp and 2 12" subwoofers, good sound, good quality, and they last a long time (I had them bridged and they still worked great) and they are cheap as well.
                1999 Camaro Z/28
                1973 Firebird Formula
                  You are a bad influence, sony hasn't made quality equiment for years. You may have gotten lucky and got a decent set but you are the acception to the rule trust me.
                    ok so i talked to crutchfeld and they recomended these. what do you think?
                    http://www.cardomain.com/item/KIC04SSMB6
                      guess i'm an exception...them sony's always been bumpin for me
                      1999 Camaro Z/28
