need help bridging channels - FirebirdV6.com/CamaroV6.com Message Board
  • need help bridging channels
    so i'm switching over from the Sony Xplods to a JL audio 10" sub. i'm using the same two channel amp for the JL, but its only one sub so it needs only one channel. i know i need to bridge the two channels into one then hook everything up normally. my question is...how? haha. i know kind of where to start but i don't know the process and steps i need to complete to do this right. do i need to go all the way back to the headunit with this or is this just something i need to handle with the amp? any help is greatly appreciated!
    1994 Camaro 3.4 L V6 <br />2.5\" Flowmaster 80 Series American Thunder Exhaust<br />SLP Cold Air Intake<br />Sony Head Unit<br />Pioneer Midranges<br />2 10\" Sony XPlod 1100 W Subs<br />Power Acoustiks 980 W Amp<br /> <a href=\"http://www.cardomain.com/id/heartbeat_of_94\" target=\"_blank\">http://www.cardomain.com/id/heartbeat_of_94</a>
    Re: need help bridging channels
    This is amp related, and is very simple. Take the + from one channel (usually the left IIRC), and the - from the other channel, and use them to power the subs. Leave the other + and - along. Although, I'm not too sure if you can do this with every amp.
    ~97 3.8L V6 Camaro~
    A few things
    Only Member of Team Hooker?!?
      i got it...it was as simple as i thought it would be. i just wanted to make sure it was right.
        Yea, not all amps are bridgeable... Plus, are you sure if you bridge it, its a wattage and impedance that matches up with your new sub?
        2000 v6 a4 Camaro
