head light problem - FirebirdV6.com/CamaroV6.com Message Board
head light problem
  • head light problem
    for the past couple of weeks, my passenger side headlight will not go up or down, the motor is fine and the fuses arent blown. and when your hit the unlock or lock button the driveers side headlight goes up and then right back down. Does anyone know where the problem might be?
    Re: head light problem
    stripped gear in the motor..
    <b>1995 Pontiac Firebird</b> || 3.4L V6
      ive already hooked the motor right to the battery and it goes up and down fine, its something else
        anyone have any ideas? i need to get it fixed soon, and don't feel like paying a shop to figure it out
          I had something similar happen. Whenever I hit the keyless entry, one headlight would act funny, come up, then go down. I found out that it was the headlight "transmission". Basically, where the knob is to manually flip it up or down. I replaced that unit and it's been fine ever since. Just sounded similar. Hope this helps.
            The "knob" is part of the motor. Take a look at the Headlight control module. Thats what tells the lights to go up and down.
              yea thats what mine does, where is the headlight control module located?
                would the headlight control module just need replaced? or is it a fuse or something else?
                  You could check the fuse's first by it will most likely need to be replaced.
                    where is this module located?
                      Where the red arrow is pointing. Right next to the fuse box.
                        alright thanks for the help guys
                          thats why you should have gotten a camaro... :)
                          #1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
