Turbo Camaro Just got dyno'd! - FirebirdV6.com/CamaroV6.com Message Board
  • Turbo Camaro Just got dyno'd!
    I went down to ZZP yesterday to get the 97 camaro on a dyno for the first time ever.
    For those who dont know, I have a custom turbo setup, Garrett T3 exhaust side and T4 compressor, intercooled built by Scott in Indiana. (Sorry Scott, but I had to)
    Port and polished heads with upgraded valvetrain, ported intake, Stage two turbo cam, 3.42s and posi. A lot more actually, but those are the main components.
    After tweaking a few numbers, I put down 414hp to the wheels at 16psi using 110 octane. We tried going up to 17-18psi but my crappy hose clamps holding the pipe sleeves together kept blowing off, plus we maxed out the MAF. I left the setup to run at 15psi for street driving since I didnt want to get to lean with a maxed out MAF. @ 15psi put down 403hp. Good day tho!
    - Neal
    SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
    Re: Turbo Camaro Just got dyno'd!
    very nice, any pics of the setup or video of the dyno.
      Nice #'s.
        awesome, time for track numbers!
          amazing! Do you have any pictures?
          1998 Chevy Camaro 3.8
          1997 Chevy Camaro Z28 - SOLD 7-23-2011
          1996 Chevy Camaro Z28
          2001 Pontiac Firebird Formula
            Thanks guys! I can get some pics of the car setup and the dyno graph, it may take a bit but I will post them soon. I do not have any pics or videos of the car on the dyno, unfortunately....ZZP def does good work with their dynos.
              Oh man that is awesome!
              3M MAFIA
              ________
              | Dynomax Catback | Auburn Posi | 3:42s | B&M Ripper | DIY CAI | PVC Mod |
              Next on the list: GT2 Cam| 105# Springs |Headwork| Headers |
                That is extremely sweet! I think I had you start it up for me at the M&G back in June. Very, VERY nice ride. Fantastic numbers too! Congrats!
                  those are healthy numbers you have a stock block?
                    Yes, It is a stock block with stock crank assembly pushing 150,000 miles on it! Stock T5 trans as well.
                    Steddy - Yea def remember you. You goin to the Dream Cruise this year?
                      Better watch that 3rd gear in that M5, maybe sometime I'll get mine going, just need the heads and etc. installed and the methanol hooked up to the TB and a new back so I can install my setup. I just got my final piece for the turbo kit, a 1 way water check valve for the water return hose off the turbo , so water won't back up and be sucked back though the radiator to keep the turbo cooler. These damm AZ temps are crazy so I'm trying to bulletproof the setup for the extreme temps. Very Nice #'s though I hope to come close to those with 10-12LBS of boost.
                        Hope all works out for your setup. Seems like you have a more stout bottom end then mine has so you should be fine running that level of boost all day long. I do not think you will need the meth at 12lbs tho. Turn that sucker up to 20lbs and spray that meth and se what 500hp feels like!
                        - Neal
                          thats sweet i would like to run a turbo set up soon i just got done building a motor for my car to replace mine with 240000 miles. but i built it for boost. cant wait to get it in
                            - Neal
                            In winter maybe but summer, theres no way, just N/A with 160 thermo and manual fan switch and bigger radiator with water and RP Ice in runs 215 degrees, IAT's about 120-140's. So I think with a turbo ,I'll run 160+ IAT's. So I think I'll have the meth at 4-6 PSI starting and the progessive controller can scale it up to max boost, thats the plan anyways. If I ever get it done.LOL
                              As long as my baby comes out of the paint shop. There's a new spot MiFbody's going to be at. Think it's more north. I thought that was you. Very nice ride, man. As I was getting done with mine, my bro-in-law tells me "Oh I know a guy with a dual turbo that would hook it up free for the testing". Then again, if I had a nickel for every time I heard "you could've got it cheaper" after the fact, I wouldn't have to worry about cheaper. LOL! I hope to see you out there, our cars should be visible at the new spot. I'll PM you with the details as I get them.
