Alright I'm to the point of finalizing my turbo build, and the biggest obstacle in my way is the oil drain. Simply put, I don't want to drill a hole in my pan. I've been told it can go in the front cover, but I'm not sure where. Been told to find a oil plug on one of the heads, but I feel like that's higher than where my turbo will sit. So, I'm looking into scavenge pumps. On tech, it looks like people have had good luck with them. Anyone here tried?
Oil drain options
Re: Oil drain options
Electric scavenge pump with a check valve to prevent the oil from running backwards after it is shut off. Summit/Jegs or some of the speed shops that do the remote mount turbos.
Run it into the plastic filler cap on the valve cover unless you've got that vented for the crank case ventilation.
I'll just be returning mine to the pan, but the engine isn't in the car for the fab work so that'll make it easier.
I tapped the pan , not very hard and works great. Mines tapped right above the oil sensor.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
