3.4 turbo?!? - FirebirdV6.com/CamaroV6.com Message Board
3.4 turbo?!?
  • 3.4 turbo?!?
    what all would be envolved in adding turbo on a 3.4. and this may seem like a very stupid question, but is it possible with a carb setup? thanx..
    mike (loomdog)
    i dunno if u can change a 3.4 over to carb and even if u could find a way y? it would be easier to just stick with the sfi.
    just my .02 hope it helps some
      I looked at your profile, I see that you do have a carbed motor. Your conversion to a 3.4 w/carb is the first I've heard. you might be better off with a supercharger setup. There might be one for the 2.8 blazers out there. Although the most funnest part of either one will be a carb adator.
      2013 Ram 1500 Big Horn
      94 comero 3.4
        now that i thunk about it, try www.turbobuick.com or some other sites that deal with carbed turbo applications. (duh [img]graemlins/dunce.gif[/img] )
        94 comero 3.4
          ill look into the buick site.. the only reason im using the carb is cali smog. i can drop in the 3.4 and pass it as the stock 2.8, but ill have to keep the carb for that to work (avoid a $300 recertification fee). i would much rather perfer the sfi or earlier mpfi setup (a little more power, less cold start problems). my goal is to have a 300 rwhp [img]graemlins/burnout.gif[/img] cali smog legal [img]graemlins/omg.gif[/img] v6 :D .
          mike (loomdog)
