Megasquirt and FI tuning question - FirebirdV6.com/CamaroV6.com Message Board
  • Megasquirt and FI tuning question
    I was searching posts and one thread seemed to suggest that I could skip complicated tuning and buying the 500$ HPtuners programmer to tune my low-boost setup, if I bought a megasquirt? Is this true?
    I'd be using either 27 or 36# injectors, and wouldn't run more than around 7#'s of boost.
    <b>99 Pewter Metallic Camaro</b><br />SLP Ultra-Z Hood, Shaved Antenna, !mouldings, Chrome Halos, Filled Factory Grill, Y2K 18 R 19 F, SLP Whisper Lid, (functional w/ Hood), FlowMaster American Thunder C.B, QA1 Coilovers, Kuhmo Tires.
    You want to avoid complicated tuning by skipping HP Tuners and getting a Megasquirt system? I think you may have that a little bass ackwards. Megasquirt is all custom stuff, replacing much of the PCM's functions. Compare that with just editing a couple tables in HP Tuners.
    Matt
    1998 Mystic Teal Camaro M5
      Yeah, I posted that before finally finding the main MS site, and reading that I'd have to basically rewire my ignition and fuel system.
      I think I'll pass.
        It is pretty complicated. Even though I run it and love it it would still be a better option for most to just go with hp tuners. At least for those that can use it. I still don't like the inability to tune for boost and have the MAP sensor actually see greater than atmospheric pressures. But I guess the MAF could compensate?
        Wayne<br />94 5 spd Camaro<br />Turbo/Intercooled<br /> <a href=\"http://www.geocities.com/Mustang732/cars.htm\" target=\"_blank\">http://www.geocities.com/Mustang732/cars.htm</a> <br /><br />Megasquirt Stand-alone EFI controling fuel/spark w/ wideband:<br /> <a href=\"http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html\" target=\"_blank\">http://home.att.net/~basic-4/2ndMegasquirt/NewMegasquirt.html</a>
          [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img] i max my MAF in one second.... its gone no more maf... no map... just me and my wideband
          from 2-3 LB/lb to over 37.83 lb/min in ~one second = fun
          www.turbov6camaro.com
          1997 3800 Series II Camaro
            I looked into the megasquirt too but I found out that no one has successfully gotten the megasquirt to work on a 3.8 motor yet.
            1997 Camaro Y87. Turbo.<br /><a href=\"http://pureoctaneracing.net/\" target=\"_blank\">Pure Octane Racing</a>
              Anyone could be the first! :D
