Were the 4th gen V6 Camaro's ever offered without A/C or is there an aftermarket A/C delete pulley that will fit a Camaro 3.8L ?
3.8L A/C delete pulley?
Re: 3.8L A/C delete pulley?
AFAIK there is not one for the RWD 3.8 setup. I'm sure you could make your own, or use a different belt routing to achieve the same result.
I used the FWD A/C bracket and bypass pulley (driver side of engine) on my Corolla but then again I have a completely different set of clearance issues and no power steering to worry about. Although I wonder if you could use the FWD P/S pump and run different lines. Might be a possibility but that is a lot of work for just an A/C bypass :p
