the squeaks continue...i'm getting pissed..UPDATE - FirebirdV6.com/CamaroV6.com Message Board
  • the squeaks continue...i'm getting pissed..UPDATE
    this is an on going battle.. i have masive squeaks coming from the rear. i tried everything. i removed spare tire and jack. lubed everything.. it coming from the hatch area. it's so annoying. if i rev the car really hard it even squeaks.. it sounds like a metal on metal. it coming from the hatch area. i put wd-40 on everything and it still squeaks.. i'm thinking of removing that plastic piece on the bottom of the hatch... also i have poly bushing everywhere.. can those cause squeaking.. maybe my panhard rod bushings need to be lubed.. this is driving me nuts.. it makes me want to sell my car..
    UPDATE::::: after gutting my interior last night i have come across many things. first off the squeaks are coimng form inside the car... with all the carpet removed i can hear squeaks at idle.. also it's coming from the bumper area.. i really think it's my hatch latch, or in that general area. i dod have the RS package and my my spolier needs to come off and be put back on. i'm going to have someone drive my car and i'm going to sit in the back and find out the exact location of the squeaks.. i will win this battle today [img]graemlins/evilgrin.gif[/img] [img]graemlins/evilgrin.gif[/img]
    [ March 26, 2003: Message edited by: malloynx#2 ]
    [ March 26, 2003: Message edited by: malloynx#2 ]</p>
    Have you checked the nuts on the top post of your rear shocks? If these have worked themselves loose, it can cause a really annoying squeaking at the slightest movement of the car (getting in/out, etc.)
    1997 Y87 Camaro with a motor and some stuff.
      Sorry dude... but this could be a number of things.
      It's one of those problems that will drive you nuts, even in your sleep. You'll work your @ss off trying to find it... only to realize your standing in front of a pile of nuts and bolts saying, "Holy Sh!t. Is that my car?"
      All I can say is.... Good Luck! [img]smile.gif[/img]
      [ March 25, 2003: Message edited by: HPbyChevy ]</p>
      Zobe
        i'm gonig to check everything tonight. tanks for the tips///
          What kind of exhaust setup do you have? I know that when i got mine the muffler it has the little rod to connect underneath the car to hold the muffler up and that can be rubbing on metal...that is what mine was doing i surrounded that the little piece of metal in ducktape and now the squeaking is gone
          96 3.8l green camaro Y87 <br />(Sold January 28th, 2004) New whip (02 Civic SI)<br />\"Out with the bad..in with the good; out with the bad in with the good!\"<br /> <a href=\"http://members.cardomain.com/themeangreen6\" target=\"_blank\">http://members.cardomain.com/themeangreen6</a>
            Get a big@$$ stereo system. That's how I blissfully ignore my interior squeaks and rattles.
            DK
              <blockquote>quote:</font><hr>Originally posted by malloynx#2:
              also i have poly bushing everywhere.. <hr></blockquote>
              Bingo. Do a search in Suspension.
              ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
                mike i had this real annoying squeak chirp sound and i figured out that it was my rear bumper. push down on it and see if thats it, if not i bet its the shocks.
                Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
                  Make sure the shock bolt is centered in the hole and not tounching the edge of the hole. That will cause constant squeaking.
