my ride is 92 v6 3.1 pontiac firebird. should i have oil light in it? i do have oil light logo in the dash board,but i dont see it flashing not even when i change oils.
92 firebird and oil light??
I think the light is supposed to illuminate when you turn the key to the "on" position until you start the car. After that the pressure should build up almost instantly and the light will go off. If that doesn't happen you may have a bad bulb.
Sometimes it won't even flash when you change the oil if you prefill the filter first.\'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...4 hours ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....4 days ago
